DDR-Dual data rate. 800mhz is what they are running. I doubt your board supports 1366mhz ram, most support 1066 or 1200 at most. Your probably thinking of FSB which is the chip not the ram. You can try to overclock them until you run into stability issues. Also massive heatsinks on ram doesn't necessarly equal massive overclocks.
