1 - 14 of 14 Posts
Excel Guru
I would like to attempt to reduce the timings of my RAM, but I only see a way to increase the VDIMM via AI Booster. Is there a program to change the RAM timings as well?
why not just go directly into the bios to change them?
you should have all the functions you need right there plus you know you have compatibility rather then a program which might/might not work
Excel Guru
Discussion Starter #4
I just now found the option to allow me to change the RAM timings manually. Wasn't exactly in the spot that I would expect...
How high does your BIOS let it go? i know mine limits me to 2.1v.
i wouldn't go over 2.1 to be safe. unless you have good airflow over the heatspreaders.
Excel Guru
Discussion Starter #12
With only 2.1V? If there is, then that is why I want to know what the limit is. For example, my Pentium D 930 has a listed limit of 1.4V, and a general rule I have heard is do not exceed 10% past the listed maximum, so I shouldn't go past 1.54V for my vcore.
ooo, noo sorry not with only 2.1v.
1 - 14 of 14 Posts
