Try loosening the timings on the ram so that you can clock it higher. That should get it a bit higher for ya.
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: Auto
CPU Clock Ratio ......................: 6
Fine CPU Clock Ratio..................:
CPU Frequency ........................: 2.5ghz
************** Clock Chip Control **************
>>>>>> Standard Clock Control
CPU Host Clock Control................: enabled
CPU Host Frequency (Mhz) .............: 400mhz
PCI Express Frequency (Mhz) ..........: 100mhz
C.I.A.2 ..............................:
>>>>>> Advanced Clock Control.........: [Press Enter]
CPU Clock Drive.......................: 700
PCI Express Clock Drive...............: 700
CPU Clock Skew (ps)...................: 0
MCH Clock Skew (ps)...................: 0
*********** DRAM Performance Control ***********
Performance Enhance...................: standard
(G)MCH Frequency Latch................: 400mhz
System Memory Multiplier .............: 2.00D
Memory Frequency (Mhz) ...............: 850
DRAM Timing Selectable ...............: Manual
>>>>>> Standard Timing Control
CAS Latency Time......................: 7
tRCD .................................: 7
tRP...................................: 7
tRAS..................................: 20
>>>>>> Advanced Timing Control........: [Press Enter]
tRRD..................................: I didn't touch any of these
tWTR..................................:
tWR...................................:
tRFC..................................:
tRTP..................................:
Command Rate (CMD) ...................:
>>>>>> Channel A Timing Settings......: [Press Enter]
Static tRead Value....................: I didn't touch any of these
tRD Phase0 Adjustment.................:
tRD Phase1 Adjustment.................:
tRD Phase2 Adjustment ................:
tRD Phase3 Adjustment.................:
Trd2rd(Different Rank)................:
Twr2wr(Different Rank)................:
Twr2rd(Different Rank)................:
Trd2wr(Same/Diff Rank)................:
Dimm1 Clock Skew Control (ps).........:
Dimm2 Clock Skew Control (ps).........:
DDR Write Training....................:
>>>>>> Channel A Driving Settings.....: [Press Enter]
Driving Strength Profile..............: I didn't touch any of these
Data Driving Pull-Up Level............:
Cmd Driving Pull-Up level.............:
Ctrl Driving Pull-Up Level............:
Clk Driving Pull-Up Level.............:
Data Driving Pull-Down Level..........:
Cmd Driving Pull-Down level...........:
Ctrl Driving Pull-Down Level..........:
Clk Driving Pull-Down Level...........:
>>>>>> Channel B Timing Settings......: [Press Enter]
>>>>>> Channel B Driving Settings.....: [Press Enter]
********* Motherboard Voltage Control *********
Voltage Types...........Normal..........Current
>>>>>> CPU
Load-Line Calibration.................: enabled
CPU Vcore..............1.325000v......: 1.425
CPU Termination........1.200v.........: 1.3
CPU PLL................1.500v.........: auto
CPU Reference..........0.780v.........: .863
>>>>>> MCH/ICH
MCH Core...............1.100v.........: 1.4 (I also tried 1.5 and failed)
MCH Reference..........0.800v.........: .943 (with the above test this was at 1.03)
MCH/DRAM Ref...........0.900v.........: auto
ICH I/O................1.500v.........: 1.59
ICH Core...............1.100v.........: 1.3
>>>>>> DRAM
DRAM Voltage...........1.800v.........: 2.1
DRAM Termination.......0.900v.........: auto
Channel A Reference....0.900v.........: auto
Channel B Reference....0.900v.........: auto
Originally Posted by ColdFusionWi ![]() If my ram is supposed to be able to run at 500 fsb and it can't even do 425 does that warrant sending it back to G.Skill and getting another set? |
