Hey all, alright I've been doing my research but when it comes to RAM it's still kind of fuzzy to me. First off, the ram I have is worthless garbage. It's one 2gb stick and one 1gb stick. It's ddr2 400mhz right now I have it clocked to 500mz 6-6-6-18. Right now I can get my 7550 stable at 3.1 but it feels like it has so much more. Right now I've been folding with 100% load for over 7 hours and the cpu temp never broke above 33c so temp is not an issue (don't you love winter?) Every time I try to go up to 3.2 I can run orthos and 3dmark together for about 12 hours then it blue screens otherwise it's fine at 3.2 when I don't put it on full load for extended time. I'm really interested to see if it's the ram holding me back from over clocking more or is the cpu just at its maximum stability limit. How can I tell what is holding me back between the ram and cpu? I'm on a pretty tight budget, what ram would you recommend to try and get more from my OC? Thanks in advance. +Rep to the person who recommends the best ram I end up buying.
