RAM usually is the worst performance vs. price item you can buy.
If on a budget, it should be treated as icing on the cake.
Originally Posted by StepsAscend Both of those are ddr400 sticks. Why not get DDR533 or so since I'm overclocking anyway and its about the same price? |
Originally Posted by StepsAscend What kind of performance increase will I see running ram at 270 rather than 220? Would I be better off with a CPU with a higher multiplier, like a 3700 SD or an Opteron 148? I don't wanna wait and save up more, cause that's not fun, but if its truly a better choice I will. |
