1 - 10 of 10 Posts
My Build so far: https://pcpartpicker.com/user/kingyoshi9/saved/P4F7RB
Uses: Gaming, Video Rendering, Running multiple simultaneous Virtual Machines for application and network testing
I am looking for 128GB RAM kit suggestions for the above build.
(Price is not a consideration, I am looking for performance.)
I also have heard of some compatibility issues with getting 128GB kits working with Asus ROG ZENITH II EXTREME ALPHA EATX sTRX4 Motherboard's.
Is this true? If so, I could downgrade to a 64 GB kit, but generally want more RAM for simultaneous VM's I run for testing.
I generally build my computers to last for 10+ years with only upgrades to RAM, Harddrive and the GPU.
My current build is from 2010, has been through 8 moves and still runs everything without any problems.
The only reason I am being forced to build something new is that my processor is not supported by Windows 10/11, therefore I cannot upgrade to it.
Any one of these will work great:
Discussion Starter · #3 · (Edited)
Thank you for the link.
But I was looking more for Benchmarks and reviews for specific ram that has already been used and tested with my Asus ROG ZENITH II EXTREME ALPHA EATX sTRX4 motherboard.
I do like the "F4-3600C14Q2-128GVKA" kit though, but am unable to find any benchmarks or reviews on this specific kit with my motherboard.
(Also, the only place that seems to sell it is newegg. I could not find it anywhere else.)
Robotic Chemist
Those are amazing DIMMs, that kit is super impressive. I seriously doubt you will run into issues with it, but I don't have any experience with that kit on the board.
I expect you haven't seen other reports because they are fairly new and not many get memory that good for 3970X systems. There are a lot of memory options so you often cannot find people testing your exact combination.
Would you provide a link or two regarding discussion of this? The PCPP page you link to discusses issues using 256GB of RAM, but 128GB is a lot less effort (depending on whether using 16GB or 32GB DIMMs). Motherboard manufacturers are usually quite conservative regarding claims for RAM, and they also rarely update QVL lists, so if a board came out before general availability of 32GB DIMMs, most boards will say 128GB is the maximum... even if 256GB will work.
Thank you everyone for all of your replies.
I will give this kit a shot and see how things go. :)
Yes, there were discussions regarding the larger kits for the board that had made me nervous.
I would need to see if I can dig through my history to find the articles.
Thank you for the additional information.
One thing I'll add is that on first gen Threadripper, I had an issue with a work system where a pre-matched set of 8 sticks had two of them (totalling 32GB) not show up until I first booted the board with a single stick, then shutdown, popped all the rest in and started it up again. Since that time, even with a long-term loss of AC power, it's never been a problem. I just put it down to first-gen early bird teething issues at the time as this was just a few weeks after Threadripper was released...
If you do find the articles, that would be great. Thanks! :)
I'am using the same mobo with 3970x and the F4-3600C16Q2-256GTRG Kit. The first time the pc wont boot so i placed only 128gb which worked and then i added the next 128gb.
This kit runs great!
But i would not go with the 128GB 3600 CL14 because Threadripper would not be much faster in Aida64 bench.
A long time ago i got a 256gb CL18 kit and i would say i does not matter CL16 or CL18.
In germany you can preorder the 256GB CL16 Kit for the same price like the 128GB 3600 CL14,
so i would prefer the 256gb kit.
Also preordered for a month ago a second 256gb ram kit - hopefully G.Skill can deliver amazon soon. ;)
BTW, you should know Wendel's 256GB CL18 video:
Thank you for all of the information and the video! :)
1 - 10 of 10 Posts
