1 - 8 of 8 Posts
Hopefully this thread is in the right place...
I need to know what everyone suggests as far as the best performance booster for the money for my rig. I currently have this ram 4GB DDR2 PC2-5300 Speed: 333 (DDR2 667). I would like to add more. I also would like to overclock my cpu at some point...and maybe the ram if its possible. Here is what my mobo will hold:
2 x DIMM, DDR3 1333/ 1066/ 800 MHz, non-ECC, un-buffered memory
4 x DIMM, DDR2 1066/ 800/ 667 MHz, non-ECC, un-buffered memory
My options as I see it:
Replace all my existing ram (2 2gig sticks) with 1066DDR2 and place a total 8 gigs in.
Keep existing and add 4 more gigs of the same as I have now
Replace current with DDR3 1333 - 4 gigs? 8 gigs?
Any other options I'm missing? Can I combine same memory but different brands?
Thanks for any help you guys can provide!
My wife and I have a photography business. We do alot of photo editing and video editing. She does 90% of the work, I do the upkeep on the computers. So I guess we just want something that will help her work more efficiently (reduce loading times, read, write times, etc) yet also allow me to play BFBC2 on high settings with a high FPS...
You're not going to get a huge boost in your gaming from the memory. Video and (some) photo editing will use as much RAM as you can throw at it. I still think, if you can fit your OS, your photo editor of choice, the photos or videos you're working on, and BC2 on an SSD in your budget.. get one.
Discussion Starter #5
I plan on getting an SSD or two for my next build which people from here are helping me pick parts for. However, I currently think the best bet for this current cpu that won't sacrifice work downtime will be to add RAM. With that being said, what type of RAM do you suggest? I know you suggested DDR3 but 4 gig sticks aren't cheap. Will I see any performance gain using 4 more gigs of the same ram I have now? I plan to OC this machine a little bit, but not much.
If you're already running 4GB, unless you can confirm you're maxing it out and hitting the swap/page file a lot, then I wouldn't add any more ram.
1 - 8 of 8 Posts
