ram timings help
677 11
i need some timings for my ram i have had a reply before but all i got was 4-4-4-12 but i need to know where i put each of the numbers thanks for ya help
1 - 12 of 12 Posts
Originally Posted by daz4400x2
i know all that i just want to know where the values go when im in that setting
Ok, I see, do you want to overclock your memory (faster speeds, looser timings), or leave it stock? (stock speeds but faster timings)
he's probably seeing someone suggested the ram timings of 4-4-4-12 for his ram timings. But those timings are horrible, that's ddr2 status. the highest you should raise your timings to would be 3-3-3-8. the numbers are cas latency, ras to cas delay, ras precharge, and cycle time (tras) respectively. What are your timings currently, why are you raising them, and who the heck told you to raise them that high? If you don't know what your ram timings are, you can use CPU-Z to find out.
1 - 12 of 12 Posts
