ram timings
254 Views 3 Replies 4 Participants Last post by  logan
whats better performance wise?
4-4-4-12 @800
or
5-5-5-12 @1066
1 - 4 of 4 Posts
The 1066 setting is a tad faster, but not by much.
I would actually bet that it could vary from system to system, with how much AMD likes tight timings. It might be worth while to just run a few benches with each setting to see what your system likes.
I had the same quandry when I built so I did my best to split the difference and by 900mhz memory that ran at 4-4-4-12
My rig benches slightly better with DDR1000 and 5-5-5-15 2T, vs the DDR750 4-4-4-10 1T that I had it at for a while, so it really depends.
Like Pao said, getting the balance between timings and speed is where the best performance is.
Good luck
1 - 4 of 4 Posts
