1 - 11 of 11 Posts
ok i have ocd my 640 to 3.7 and now i whant to deal with my ram
so i can get better timing ect
my mobo is a foxconn A6GMV
here are some pics of ram
both pics from same stick and my ram are matching
bios images
what settings do i change
this thread shows my oc settings
http://www.overclock.net/amd-cpus/98...burn-test.html
Originally Posted by Kal777
Hmm 1.0060v for ddr3 is pretty low, you could incease it to 1.500v and try dropping your timings to 8-9-8-24-88
just upping some bios images see origonal post
Discussion Starter · #6 ·
You want to change your CAS to TRC in the order of 8-9-8-24-8-88 were CAS is 8 and TRC is 88.
so stop changing from auto at trc thanks will do that
also my bios set the ram voltage to 1.5 should i leave it or put it to 1.6
ok i can change 2 - 8-9-8 but the rest i cant as the available numbers are different
Discussion Starter · #11 ·
current timings
1 - 11 of 11 Posts
