1 - 6 of 6 Posts
I've never used that BIOS, but it looks to be tallying only the "enabled" row. Is there way you can enable the other two DIMMs?
Originally Posted by lucifer666 View Post
nope, theres nothing!
dont know what to do!
if i put the ram in slot 3 and 4
then 4gb are enabled
but channel A doesnt read any timings then
this ram is staring to piss me off!
Assuming there isn't a setting I don't know about, it's obviously either the RAM or the board. If other sets of RAM work fine, I would say it's the RAM.
2x2gb, right? I have the p55-ud2. Try slot 1&3 if that don't work try 2&4
1 - 6 of 6 Posts
