1 - 8 of 8 Posts
The Ripjaws, better timings, what's the timings/voltage on the Crucial ram?
EDIT: Crucial is 8-8-8-24 at 1.65v
Yeah, go with the Ripjaws just slightly lower timings.
http://www.crucial.com/pdf/Ballistix...5664FN1608.pdf
they are here mate
I know the gskill are slightly better on timings but are these crucial ones good? as they are £120 odd new seems im getting a good deal...
If i go for the gskill its an extra say £30 just for 1 less timing on 2 figures?
$160 for DDR3 ram at those timings/voltage is okay, kinda over priced IMO.
I said G.Skills just because they're reputable, Corsair is good as well.
Discussion Starter #5
i bought the g-skill ripjaws at 91 timings are good at 7-8-7-7-24 or whatever it is. It's gaming ram apprently!
In this case I'd normally suggest the similar G.Skill ECO CAS7 over that set of Ripjaws, but the store doesn't appear to stock them. It's a bit pricier than the rest but when you consider the timings vs. the other prices all-around it's probably not so bad. AMD likes 1600 CAS6-7.
Discussion Starter #7
So ive done good by getting those ripjaws at cas7 then?
ripjaws : http://www.overclockers.co.uk/showpr...=8&subcat=1517
1 - 8 of 8 Posts
