Are you giving the NB enough volts?
[CODE]
ASUS Rampage Formula BIOS 0407 Template
*Extreme Tweaker*
Ai Overclock Tuner [Manual]
CPU Ratio Setting [6]
FSB Strap to North Bridge [Auto]
FSB Frequency [366]
PCIE Frequency [100]
DRAM Frequency [712]
DRAM Command Rate [Auto]
DRAM CMD Skew on Channal A [Auto]
DRAM CMD Skew on Channal B [Auto]
DRAM CLK Skew on Channal A [Auto]
DRAM CLK Skew on Channal B [Auto]
DRAM Timing Control [Manual]
1st Information
CAS# Latency [5]
RAS# to CAS# Delay [6]
RAS# PRE Time [6]
RAS# ACT Time [18]
RAS# to RAS# Delay [Auto]
REF Cycle Time [Auto]
WRITE Recovery Time [Auto]
READ to PRE Time [Auto]
2nd Information
READ to WRITE Delay (S/D) [Auto]
WRITE to READ Delay (S) [Auto]
WRITE to READ Delay (D) [Auto]
READ to READ Delay (S) [Auto]
READ to READ Delay (D) [Auto]
WRITE to WRITE Delay (S) [Auto]
WRITE to WRITE Dealy (D) [Auto]
3rd Information
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
DRAM Static Read Control [Auto]
Ai Clock Twister [Auto]
Ai Transation Booster [Auto]
Common Performance Booster [Auto]
Pull-In of CHA PH1 [Auto]
Pull-In of CHA PH2 [Auto]
Pull-In of CHA PH3 [Auto]
Pull-In of CHA PH4 [Auto]
Pull-In of CHA PH5 [Auto]
Pull-In of CHA PH6 [Auto]
Pull-In of CHB PH1 [Auto]
Pull-In of CHB PH2 [Auto]
Pull-In of CHB PH3 [Auto]
Pull-In of CHB PH4 [Auto]
Pull-In of CHB PH5 [Auto]
Pull-In of CHB PH6 [Auto]
CPU Voltage [1.2]
CPU PLL Voltage [Auto]
DRAM Voltage [1.8]
NB Voltage [1.31]
FSB Termination Voltage [Auto]
South Bridge Voltage [Auto]
SB 1,5V Voltage [Auto]
Loadline Calibration [Enabled]
CPU GTL Voltage Reference [Auto]
NB GTL Voltage Reference [Auto]
DRAM Controller Voltage REF [Auto]
DRAM Channel A Voltage REF [Auto]
DRAM Channel B Voltage REF [Auto]
CPU LED Selection [Auto]
NB LED Selection [Auto]
SB LED Selection [Auto]
Voltiminder LED [Auto]
CPU Spread Spectrum [Disabled]
PCIE Spred Spectrum [Disabled]
*Advanced settings*
C1E Support [Disabled]
CPU TM Function []
Vanderpool Technology []
Execute Disable Bit []
Max CPUID Value Limit []
