5
Hey all,
I've run into a weird situation and was hoping to see if anyone had some thoughts.
I had a GTX 295 but took it out (long story). Everything was fine and no problems.
After installing a BFG GTX 280 OC Version I started having problems. The first time around the system crashed with the blue screen. I turned off the system via case power button. I then proceeded to turn the system back on. The system and the components would power up but it would not boot and cycle through the lcd poster. I then turn off power by holding the power button for a few seconds to turn off system. Next, I turned off
main power by switching the psu switch. I then switch atx power back on (after 15 seconds) and the system would boot after clicking the power button on the case. However, it would take me a to a prompt menu saying "Overclocking failed! Please enter Setup to re-configure your system. Press F1 to Run Setup. Press F2 to load default values and continue." I hit F1 go into setup, everything looks good including memory on xmp settings. I don't change anything in the bios. I click save and exit and once I exit the bios menu it boots fine to windows.
The last two days I would get the same problem. That is once I shutdown from windows when I power up the system from a cold boot system powers on but nothing happens. It's on but no boot or bios cycle. I then again turn off the system via the power button then proceed to turn off
main power by switching the psu switch. I then switch atx power back on after 15 seconds. I click the case button for power and system boots then takes me to that same overclocking failed prompt where then I once again go back into bios look at the settings, click save and exit without changing anything and then am able to load the system to windows.
In the morning I had the same problem. I would do what I mentioned to get the system to windows.
About 6 hours later I booted the system from cold start and its fine no problems... 2 hours later I booted again from cold start and no problem. This is really confusing the hell out of me. I am going to give it some time see what happens before I must go to the next level. I am hoping that someone may have any ideas or suggestions about this issue.
Thanks!
I have also flashed the bios 0804 and even switch bios on the board but it does not seem to have a direct effect on fixing this issue.
The attached picture is what happens when I get the system up from cold boot. Also a pc probe screen shot and cpuz screen shot.
