The ASUS ROG Rampage III Extreme thread!
Welcome to the Rampage III Extreme information thread! Here you can discuss the board and share your impressive OC's with other clockers!
Add your overclocks here!
http://spreadsheets.google.com/pub?key=t5UH44_mKyHIlQn7SvbCp0g&w=75&h=500 Google Spreadsheet
Final specs: CPU -Intel® Socket 1366 Core™ i7 Processor/Core™ i7 Processor Extreme Edition Chipset -Intel® X58/ICH10R Memory - 6 x DIMM, Max. 24 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC, Un-buffered Memory modules - Tri Channel memory architecture Expansion Slots - 4 x PCIe 2.0 x16 Supports x16; x16/x16; x16/x8/x8; x8/x8/x8/x8 configurations - 1 x PCIe x4 - 1 x PCI 2.2 Storage Intel® ICH10R Southbridge -6 x SATA 3.0 Gb/s ports , Intel Matrix Storage Technology Support RAID 0,1,5,10 JMicron® 363 controllers: - 1 x SATA 3.0 Gb/s port (Black) - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go) Marvell® PCIe SATA 6Gb/s controller - 2 x SATA 6.0 Gb/s ports (Red) LAN - 1x Gigabit Intel® PHY Audio 8-channel High Definition Audio CODEC, Support Blu-ray audio layer content protection USB NEC® USB 3.0 controller - 2 x USB 3.0/2.0 ports (at back I/O) Intel® ICH10R Southbridge - 9 USB 2.0/1.1 ports (2 ports at mid-board, 6 ports at back I/O, 1 port at back I/O reserved for ROG Connect) Bluetooth Module Accessory Card -Bluetooth V2.0/V2.1+EDR -RC Bluetooth On/Off Switch Clock generator for R3E (useful for setFSB)(courtesy of xxbassplayerxx) ICS9LPRS926EGLF Software -Futuremark 3DMark Vantage Advanced Edition -Kaspersky Anti-Virus Form Factor extended ATX Form Factor: 12 inch x 10.6 inch ( 30.5 cm x 26.9 cm ) *The board is 1 inch wider than other ATX boards so check your case for compatibility |
Features iROG Intelligent multiple control at hand The iROG is a special IC which enables several ROG highlighted functions that gives users full disposal of the motherboard at any stage! This design allows advanced user control and management to be processed purely at a hardware level. iROG greatly increases fun during overclocking for PC enthusiasts and it offers system maintenance and management with more control and efficiency. USB BIOS Flashback No worry of BIOS crash anytime! USB BIOS Flashback must be the most convenient way to flash BIOS ever! It allows overclockers to try their BIOS with the simplest way one can imagine. No need to enter the BIOS or the operating system, just plug the thumb drive into the ROG Connect port & push the ROG Connect button for 2 seconds, BIOS would be automatically flashed under standby power. It´s no doubt that USB BIOS Flashback gives overclockers the ultimate convenience. Voltiminder LED Friendly reminder on Voltage Settings In the pursuit of extreme performance, overvoltage adjustment is critical but risky. Acting as the "red zone" of a tachometer, the Voltiminder LED displays the voltage status for CPU, PCH, and Memory in a intuitive colour-coded fashion. The voltiminder LED allows quick voltage monitoring for overclockers. Probelt Get all hands-on with hardware-based overclocking ProbeIt takes the guesswork out of locating the motherboard´s measurement points, identifying them clearly in the form of 5 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter. Extreme Engine Digi+ The implementation of Extreme Engine Digi+ was designed to enable overclockers to push the new generation of CPUs to the limit. The next-generation dynamic multi-phase power management system equipped with high performance ML Caps that ensure a stable power supply during overvoltage by lowering ESR (Equivalent Series Resistance), which successfully delivers the advantage of both analog and digital VRM all in one go, keeping mission-critical components such as the processor, system memory and the Northbridge reliable while maintaining high power efficiency. - 8-phase CPU power - 3-phase QPI/DRAM p0wer - 3-phase NB power - 3-phase Memory power - ML caps on CPU, memory and QPI respectively EZPlug More power for the power hungry monsters The Rampage III Extreme comes with two sets of E-ATX 12V, and two sets of 4-pin Molex plugs, delivering enough power for power hungry monster rigs when conducting extreme overclocking. LN2 Mode Cold-boot bug is a barrier which overclockers often need to face when conducting subzero overclocking with LN2 (Liquid Nitrogen). When the cold-boot bug occurs, the CPU will no longer POST till it has been warmed up again. The LN2 Mode exclusively supported by Rampage III Extreme enables users to remedy this limitation, delivering non-stop smooth extreme overclocking capability, which makes Rampage III Extreme the perfect choice for all overclockers under LGA1366 platform. ROG Connect Plug and overclock - Tweak it the hardcore way! Bios Flashback Two BIOS ROM. Two BIOS settings. Twice the overclocking flexibility. Extreme Tweaker One stop performance tuning shop COP Ex Maximum OC with confidence with burn proof protection to chipsets and GPU! Loadline Calibration Optimal power boost for extreme CPU overclocking! Onboard Switch No more shorting pins or moving jumpers ASUS Q-Connector Make connections quick and accurate Q-Fan Plus Optimized quietness and cooling for more devices! |
Phone support for overclocking: RC Bluetooth Overwhelm your acknowledgement with wireless overclocking experience! System Debug and keyboard-free overclocking have evolved a long way in the past years. However, regardless of any existing design, users still cannot gain the full control the system without either opening up the chassis, or simply getting back to the good old trusty keyboard. Thank to the Forth generation Asus TweakIt technology via the iROG processor, users can now gain the full control of the keyboard-free overclocking and debug tools wirelessly via their very own Bluetooth device anytime, anywhere. Supported phones -Windows Mobile 6.1/6.5 based phones -Android V2.0 or later -Symbian V3.0 or later *Fear not, iPhone support will come. |
Bundle: 1 x ROG Connect Cable 1 x ProbeIt Cable Set 1 x 3-Way SLI Bridge 1 x SLI Cable 1 x CrossFire cable 6 x SATA Cables 2 x SATA 6G Cables 1 x two Port USB 2.0 and eSATA bracket 1 x I/O Shield 1 x Thermal Sensor Pack (for fan header thermal monitoring/speed control) 1 x Cable ties pack 1 x ROG sticker and 1 x Cable label pack 1 x Optional Heatsink and fan (for IOH cooling) 1 x RC Bluetooth module 1 x Support DVD 1 x User Manual |
Latest BIOS and drivers: Go HERE. Select "downloads" then choose OS. |
BIOS template: USE: 1005 Bios Template for Copy/Paste OR: Target CPU Frequency XXXXMHz Target DRAM Frequency XXXXMHz LN2 Mode []*** QPI Loadline Calibration []*** Sync Mode [] AI Overclock Tuner [] OC From CPU level Up [] CPU Ratio Setting [] CPU Turbo Power Limit [] >CPU Configuration---------------------------- CPU Ratio Setting [] C1E Support [] Hardware Prefetcher [] Adjacent Cache Line Prefetcher [] Intel(R) Virtualiyation Tech [] CPU TM Function [] Execute Disable Bit [] Intel(R) HT Technology [] Active Processor Cores [] A20M [] Intel(R) SpeedStep(TM) Tech [] Intel(R) C-STATE Tech [] C State package limit setting [] ---------------------------------------------- BCLK Frequency [] PCIE Frequency [] DRAM Frequency [] UCLK Frequency [] QPI Link Data Rate [] Memory Configuration Protect [] >DRAM Timing Control-------------------------- CAS# Latency [] RAS# to CAS# Delay [] RAS# PRE Time [] RAS# ACT Time [] RAS# to RAS# Delay [] REF Cycle Time [] WRITE Recovery Time [] READ to PRE Time [] FOUR ACT WIN Time [] Back-To-BackCAS# Delay [] Timing Mode [] Round Trip Latency on CHA [] Round Trip Latency on CHB [] Round Trip Latency on CHC [] WRITE To READ Delay(DD) [] WRITE To READ Delay(DR) [] WRITE To READ Delay(SR) [] READ To WRITE Delay(DD) [] READ To WRITE Delay(DR) [] READ To WRITE Delay(SR) [] READ To READ Delay(DD) [] READ To READ Delay(DR) [] READ To READ Delay(SR) [] WRITE To WRITE Delay(DD) [] WRITE To WRITE Delay(DR) [] WRITE To WRITE Delay(SR) [] ---------------------------------------------- CPU Differential Amplitude [] CPU Clock Skew [] IOH Clock Skew [] ------------ Extreme Engine Digi+ ------------ Digi+ PWR Mode [] PWR Volt. Control [] Load-Line Calibration [] CPU Voltege OCP [] CPU PWM Frequency [] Extreme OV [] Extreme OC [] CPU Voltage [] CPU PLL Voltage [] QPI/DRAM Core Voltage [] DRAM Bus Voltage [] >DRAM REF Voltages---------------------------- DRAM DATA REF Voltage on CHA [] DRAM CTRL REF Voltage on CHA [] DRAM DATA REF Voltage on CHB [] DRAM CTRL REF Voltage on CHB [] DRAM DATA REF Voltage on CHC [] DRAM CTRL REF Voltage on CHC [] ---------------------------------------------- IOH Voltage [] IOH PCIE Voltage [] ICH Voltage [] ICH PCIE Voltage [] ---------- Spread Spectrum Control ----------- CPU Spread Spectrum [] DRAM Spread Spectrum [] ***on-board jumper dependant |
