1 - 5 of 5 Posts
I was just looking at some furniture websites and I got a bsod with the irq not less or equal thing, my rig isn't oc'ed at all, Whats could be the problem
Run memtest 86 on those sticks overnight:<br><br><a href="http://www.memtest86.com/" target="_blank">http://www.memtest86.com/</a>
I cant get memtest to work at all my floppy says that it unreadable when it tries to write the program, but its occt stable and microsoft memory diagnostic stable aswell
If that happens again, I would start to worry, but it might have been just a one-time glitch. Don't think too much into it!
Administrator
Do the following as ive fixed this many times. <br />
<br />
1. Make sure you have the latest BIOS installed. <br />
2. Reset the CMOS <br />
3. Make sure you have the latest drivers for the follwoing and not BETA drivers. <br />
<br />
.G-card<br />
.Chipset <br />
.Sound card. <br />
<br />
4. If you have the latest BIOS perhaps revert to one that worked fine before for you. <br />
<br />
<br />
Also i would use Windows Memory diagnostic and follow the instructions : <a href="http://oca.microsoft.com/en/windiag.asp" target="_blank">http://oca.microsoft.com/en/windiag.asp</a>
1 - 5 of 5 Posts
