Random HD slowdowns, help needed
295 Views 1 Reply 2 Participants Last post by  sdla4ever
I was having trouble noticing slowdowns with the OS (Internet/MSN would hang randomly, entire computer would lock up for a second), so I bought a new hard drive. (WD640AALS)
Reinstalled windows 7, but started noticing the same thing happening. And here is a visual of what happens.
maybe this is a bit unfair because the computer was just done starting up
so here is another, done after a period of no activity
What are these random dips? Sometimes it gets so bad that its dip after dip after dip. Games like COD6 and Dirt 2 take ages to load.
Also, the old hard drive, which I thought was responsible, is now a secondary back up drive, but its performing well, just look
So is it an OS problem or something?
1 - 2 of 2 Posts
might wanna check how often W7 puts the drives to sleep, I know it had mine sleeping every 10 minutes so all asudden it would slow then get fast.
The graphs are perfectly normal for a HDD. Might wanna check for a RAM leak and disable the page file on the OS drive.
1 - 2 of 2 Posts
