So most people probably won't read this due to the amount of posts about high temps due to vcore or poor cooler placement and such but i have looked about on the web and i think this is a fairly unique problem. I am not super experienced when it comes to computing but i wouldnt call myself a noob either, although maybe i made a newb mistake which caused the problem...but anyways.
so i was overclocked to 3 ghz right. P95 stable, good temps, 35-37 degrees. I've got a 9700cnps and a silverstone tj09 and pretty good cable management. So anyways 3 ghz was only a temporary position and i was on my way to 3.4 and if it could take it, up to 3.6. So i began overclocking again after about a month of 3 ghz and thats where i got this random heat problem. Of course i upped my cpu vcore and such and such and it was a bit hotter at my new clock, but after having trouble with stability and needing to resume work, i lowered my speed back down to 3 and my voltages all back to where they had been at. So all good right? NO. my temps stayed where they had risen to. 40 C. I tried overclocking again on the weekend, not really paying attention too much to this increase. (btw the ambient room temp has not moved) So after this week i have noticed that wherever i place my vcore it is around 40-43 degrees. Except when i exceed 1.4 volts and it jumps to 43-45.
In the end i have reset all my settings back to stock speed. 2.4 ghz and 1.2 vcore and i am at 40-43 degrees celsius!!!! What the heck is with that!
My cooler is placed fine and all the fans work as they did a month ago. The only thing i can think of is that i had my VTT at 1.4 because i hadn't discovered GTLREF and couldnt get it stable any other way for some reason. Also i had my NB at 1.4 i think which drastically improved stability for me.
When i noticed the heat i lowered both these voltages and saw not change in my temps. SO did i blow my cpu with high VTT or what. BTW this is a GO.
