1 - 13 of 13 Posts
Heres the story.
Last night, we had a power outage. PC turns off.
This morning, turn it on. Everything is fine, boots up normally etc. However, I get no sound through my headset on front 3.5mm. So I switch to back mobo 3.5mm. Still no sound...beginning to get worried. I then test with another pair of headphones... Front and back, still no sound.
At this point, I restart pc, try again, no luck. I uninstall the audio device in device manager, restart, reinstall with new drivers. Still doesn't work.
When I play a video, the Windows volume mixer shows that audio is being played, I just can't hear it.
Any ideas? (I'm on my sig rig.)
P.S
I don't know if I should have posted this here.... seemed relevant though.
Originally Posted by RallyMaster
It's possible that your onboard audio just got fried.
Yep, it's not too uncommon. You can buy yourself a cheap-o soundcard to suffice, or you now have a reason to get a nice soundcard.
^Pretty much what they said. Unfortunately.
this is a sign for no software issue > sadly its hardware
yeah , he has a MSI MoBo , the unbelievably unreliable mobos , chipset frying is common in MSI
the only thing to do is to get a dedicated sound card , after using it you will thank the MoBo for frying the on-board
the cheapest good card to get is Xonar DG 30$
Well, this is odd...
I just randomly start hearing sound again. It works.
Awesome!
........well........huh.....OK glad it worked , but did you do something you didn't mention in the thread?
maybe YOU can help us
1 - 13 of 13 Posts
