Randomly Unstable
389 8
Got my new rig up and running buts its randomly unstable. It just hangs for no reason. I thought it was the graphics card because it hangs at the more graphical tasks but i ran visualisations at full screen for a couple mins and that didnt hang it - usually it would. It also tends to hang when im not using the processor above 50% for a long time. Ive jumped the voltage on my overclock - 220 x 10 @1.45. It seems a little more stable - it hasnt crashed as of yet :/
I know i dont have a memory hole - i ran Memtest86+ for a good 5 hours and no errors - i can run superpi, prime95 and fold for as long as i want. Im stumped.
im going to reinstall XP to see if it was the AMD power management crap the mobo installed.
Any comments?
1 - 9 of 9 Posts
latest
it was an XP driver it installed - im never going to run the auto setups on the mobo disks again :rollseyes:
There is nothing wrong with the drivers that are installed for AMD's. It should not be causing your instability (and is most likely not).
If you feel a fresh install is the way to go, then go ahead. I think it's something else though.
Discussion Starter · #6 ·
bios reflashed - i already had revision 13
im reinstalling windows onto my laptop so i can back my stuff up - i had kubuntu on and it wouldnt let me be the root user - so im going back to xp with madrake dual boot (off topic)
ill reinstall XP with SP2 and .net. I will only install the SATA\\RAID drivers for my mobo. Does any one have any software that would tell me whats making it unstable (eg: CPU Overclock Unstable, Memory Hole, SATA etc)
Discussion Starter · #8 ·
my parents have just gotten me a graphics card. Its an ATI RX300 128. Itll see me over until i get my water cooling
(eventually)
I can get this PCI 8mg one out now, lol
Discussion Starter · #9 ·
It turns out it was the graphics card. It hasnt hung for some time now - yet *touches wood*. Im oc'ing the x300 now - the core's hit 400+ and i still need to do the memory and the CPU etc.
Thanks for the help
1 - 9 of 9 Posts
