Had some reward zone coupons totalling about $25 and a 15% off accessory coupon for BestBuy so I picked up the Razer Lycosa to go with my Razer Mat, Lachesis, and Barracuda setup. Ended up being like $50 bucks after tax... not bad! But let me tell you I AM VERY UPSET!!!
The anti ghosting on this keyboard is screwed. You cannot use the caps lock key while using any other 2 keys at once. My gaming setup assigns caps-lock for walk/sprint, shift for crouch, and ctrl for prone.
For example in MW2 you are crouched, moving forward and (strafing) left or right, you cannot just press caps-lock to initiate a sprint and stand fully. Last night it actually got me killed quite a few times before I finally said screw it and I'm not dealing with this BS and uplugged the damn board.
I called Razer support and they confirmed caps lock key cannot be used for anti-ghosting. IMO Razer really messed up. Caps lock is right next to the A key. THIS IS A GAMING KEYBOARD!!!! Come on RazerGuys use your brain!!!
So the only other Razer keyboard that will work for me is the Tarantula and hey look its discontinued! With a possibility of being remade in the near future
according to the Razer Rep, I'm still screwed if I want a Razer keyboard. The Arctosa and Lycosa Mirror are the exact keyboard hardware and will have the same problems.
The keyboard has a great feel. Gets dirty easy(so what). The lighting is noticeable but not very bright. And overall it is comfortable. It's too bad because I would be all over this board if it weren't for this issue!!!
The only reason I'm happy is because I purchased it from Best Buy and it is going to be very easy to return.
Way to mess this one up Razer!
