Raptor procrastination
380 Views 5 Replies 5 Participants Last post by  Old Hippie
Well, learn from my example people
I let 3 Raptors (2 74 gb, 1 36 gb) sit idle after failing. Instead of RMAing them as I should've, I procrastinated and now they're out of warranty
I go through hard drives like most go through laundry detergent due to extreme temperatures in my game room in summer. I've solved the heat problem, but now 3 Raptors are going in the trash!
On a happier note, Fed EX is on its way to my house with an SSD and 4 copies of Windows 7
1 - 6 of 6 Posts
Once you get a hold of that SSD, you'll soon forget about your Raptors.
Nah, I'll only have an SSD on Comp #1 for now. My friends will still have to suffer with Raptors
If you are going to throw those out is there any way i can get the two 74gb hard drives? I have always wanted to do a hard drive speaker system. I will pay for the shipping of course.
I heard you can only use 7200rpm drives because the 10,000rpm Raptors will make the music speed up.
1 - 6 of 6 Posts
