1 - 15 of 15 Posts
Well guys, anyone want to talk me out of buying another Raptor for striping? I'm bored and the local shop has 1 in stock. If anyone feels passionate about the lack of performance gain, here's your chance to voice it and talk me out of buying another one. I haven't used Raid 0 on this particular box and it would be my first Sata Raid. I've used IDE Raid for years,though. You have 1/2 hour to state your case =P Anyone vote no? Btw, I'm reformatting today anyways and is the reason for me deciding to just pull the trigger and blow a C-note.
Originally Posted by Orion14_99
if you already have 1... my vote is go for it, since i did the same thing
good luck!
Bah, my wallet hates you =P
I say GO FOR IT......all you can do is get faster.
Reactions: sccr64472
The best performance would be two, you won't regret it.
Off topic those three 633 I got from you work great, I have them overclocked to 1.1ghz and folding.
Discussion Starter #7
Wow, good to hear you like 'em! I'm guessing that they were used for a grand total of 2 weeks before I swapped 'em out for Athlon 1700s, so I wouldn't be shocked if they improve slightly after a slight break in. I still can't believe how long it took for them to ship to Arizona, though.
Btw, you got those overclocks on the motherboards I sent or a different motherboard?
Yea the postperson didn't believe me in tell I showed her the postal date. But thanks.
You will love the increase in speed when loading things....I went from 59MB/s to 104MB/s in read times going from 1 drive to 2 in raid 0.
Discussion Starter #10
I know it'll show in benchmarks, but did you honestly notice a difference in apps? If I didn't need to reformat, I'd pass on it, but I need to reformat today anyways. I've been playing a Beta that had a memory leak, so the massive crashing took out my install of Age Of Empires, so I decided to just reinstall everything instead of just that game. Seems odd that it took out a different game, but the Beta game is fine lol
Sure you do...loading games and such is a lot faster.
Discussion Starter #12
Thanks for input guys and Reps were given. I'm off to the store
i honestly notice it. it does make a big difference. when copying files and reading big ones, the time drops off noticeably. also, when loading games, it is a godsend. a LOT of times, me and my roomate and a buddy will load up bf2 and have a mini lan party, and i load the map, when ask, "ok what team are you guys on?" then the look at me, back at their screen, and its less than half done loading the map. or when i ask, they'll just look at me and say, "shut up" lol so yeah, it does make a difference loading games.
also, when loading windows the time drops off too. with just the raptors loading windows, the little bar might go across once or twice, usually not three times. when i first loaded windows after a format, it loaded so fast the bar went across once. i was happy, to say the least.. and told my friends to watch. i rebooted, and it only went across the screen 1/4 of the length of the bar, and it was loading windows. this is at stock speed by the way (1.8ghz amd) so yeah, you'll notice
Discussion Starter #14
Ok, I'm about to configure my striping array and want to double check my settings to make sure they're optimal. The last information I've seen states that having a 4:1 stripe to cluster ratio is optimal. I'm going to use 16k stripe with 4k cluster for 2 raptors. Anyone have any info suggesting a different setting? Thanks in advance for input.
Discussion Starter #15
Last call before I create my array...speak up or forever hold your peace.
1 - 15 of 15 Posts
