1 - 5 of 5 Posts
Hardware Maniac
Anyone got one and tried to see how far they get now with the 1.4 baseclock.
Just ordered one cant wait to try.
Raspberry Pi3b+ Pi3b
# # # # # # www.IRONHAMMER.info # # # # # #
#############################protects_files
boot_delay=1
#############################remove-govener
force_turbo=1
########################[email protected]
arm_freq=1300
###########################about_1per-37mhz
over_voltage=3
#######################[email protected]_sddr2
sdram_freq=500
sdram_schmoo=0x02000020
sdram_over_voltage=2
##########################[email protected]
core_freq=500
gpu_freq=500
###############################gpu/ram-spit
gpu_mem=384
#######################[email protected]=100max
dtoverlay=sdhost.overclock_50=100
# # # # # ERIK THE WRENCH YouTube # # # # #
###ram-split_FB_uses-400mb+150mb-for-Chrome
###[email protected] room temp########
###stock=92.76_51-71c_____1300=85.44_51-77c
###>=crash_under_1080p-full-screen
###[email protected]_1400/600-ram_but_crashes
###1390 sys bench corrupted
###1366==81.33_51-78c--20min/1080p_crashes!
###+1c_room=+2c-w/[email protected]=<@1300
###[email protected]_but_gets_choppy
###overall_smoothness_of_system_as_whole
###with_only_100_over_on_everything
###ram=stock_50mhz_overclocked!
###keep_gpu/core_same!
###GPU=3_sub-layers_of_VideoCoreIV
###that_should_be_the_same_anyway!
###pi3b+_same_as_b_w/_heat-dissipate
###and_power-manager_chip
###allows_1.4ghz_stock_w/_auto-overvolt
###likely_best_to_leave_1.4hz_w/_above
###overclock_settings_or_1.5(100over)
###and_No_Over-volt_on_arm.
###3b_&_3b+_claims_0175over-stable_but...
###having_all_the_clocks_multiples_of_100
###[email protected]_so_it_is_all
###multiples_of_500_will_cycle_smoother.
###so_the_arm_hits_the_core/ram/gpu_3_to_1
###of_the_cpu_other-wise_it_has_to_wait
###causing_choppy_run/wasting_clock_cycles.
###next_step=swp-dedicated-usb_thumb_drive
###it_moves_low_priority_RAM_to_disk_space.
# # # # # "numbers make me angry" # # # # #
Hardware Maniac
Discussion Starter #3 (Edited)
1.57GHZ ? With stock voltage?
Just received mine and it seem the gpu is at 700mhz instead of 400 will try to see if it just an error
edit it the core clock example in the config uh
that it throttles at half speed unless you force turbo, and the overvolt is automatic with the 3b+ , i actually fudged the numbers i just edited post!!!!! and way better notes.....
boot_delay=1
force_turbo=1
arm_freq=1300
over_voltage=3
sdram_freq=500
core_freq=500
gpu_freq=500
gpu_mem=384
Hardware Maniac
Discussion Starter #5
oh well could not ven get 1500mhz stable so back to stoc. but gpu run fine at 500mhz
default voltage is 1.35v
wonder if tubo and overvolt 8 would work il report back
1 - 5 of 5 Posts
