1 - 1 of 1 Posts
seems other than jacking it around for a single purpose built machine, these are the real numbers needed to function as a smooth operating pc, with a nice case larger fan and heat sinks, with out any issues. i crashed it a million and one times and ways. way too much time on my hands.....
# # # # # # www.IRONHAMMER.info # # # # # #
#############################protects_files
boot_delay=1
#############################remove-govener
force_turbo=1
########################[email protected]
arm_freq=1300
###########################about_1per-37mhz
over_voltage=3
#######################[email protected]_sddr2
sdram_freq=500
sdram_schmoo=0x02000020
sdram_over_voltage=2
##########################[email protected]
core_freq=500
gpu_freq=500
###############################gpu/ram-spit
gpu_mem=384
#######################[email protected]=100max
dtoverlay=sdhost.overclock_50=100
# # # # # ERIK THE WRENCH YouTube # # # # #
###ram-split_FB_uses-400mb+150mb-for-Chrome
###[email protected] room temp########
###stock=92.76_51-71c_____1300=85.44_51-77c
###>=crash_under_1080p-full-screen
###[email protected]_1400/600-ram_but_crashes
###1390 sys bench corrupted
###1366==81.33_51-78c--20min/1080p_crashes!
###+1c_room=+2c-w/[email protected]=<@1300
###[email protected]_but_gets_choppy
###overall_smoothness_of_system_as_whole
###with_only_100_over_on_everything
###ram=stock_50mhz_overclocked!
###keep_gpu/core_same!
###GPU=3_sub-layers_of_VideoCoreIV
###that_should_be_the_same_anyway!
###pi3b+_same_as_b_w/_heat-dissipate
###and_power-manager_chip
###allows_1.4ghz_stock_w/_auto-overvolt
###likely_best_to_leave_1.4hz_w/_above
###overclock_settings_or_1.5(100over)
###and_No_Over-volt_on_arm.
###3b_&_3b+_claims_0175over-stable_but...
###having_all_the_clocks_multiples_of_100
###[email protected]_so_it_is_all
###multiples_of_500_will_cycle_smoother.
###so_the_arm_hits_the_core/ram/gpu_3_to_1
###of_the_cpu_other-wise_it_has_to_wait
###causing_choppy_run/wasting_clock_cycles.
###next_step=swp-dedicated-usb_thumb_drive
###it_moves_low_priority_RAM_to_disk_space.
# # # # # "numbers make me angry" # # # # #
1 - 1 of 1 Posts
