1 - 2 of 2 Posts
Intel Core i7 930 2.80GHZ
Corsair Dominator 4 GB PC3-10666 1333MHz Dual Channel Core i3 i5 i7 DDR3 CAS 8 Memory Kit CMX4GX3M2A1333C8
Western Digital Caviar Black 1 TB Bulk/OEM Hard Drive 3.5 Inch, 32 MB Cache, 7200 RPM SATA II WD1001FALS
Antec Three Hundred Gaming Case External 3 X 5.25; Internal 6 X 3.5 2*Usb2.0
650 corsair psu
I will use my old BFG 9800gt that still works fine & the CD/dvd rom drive. Buying all the parts on amazon since I have a prime account.
What motherboard should i get that would work good for the core i7?
Comments, suggestions? Everything should work haha I think. I ain't doing any of that crazy crossfire stuff. I know its a crossfire board & I'm going to be using a single nvidia card.
the Intel i7 930 uses triple channel ram ( so 3 sticks of ram )
get this ram kit
http://www.newegg.com/Product/Produc...82E16820231247
also, that graphics card is going to be a huge bottleneck for your processor i suggest you get either a 58xx ATI card or a 4xx series nividia card
this case is cheaper and better then the Antec 300
http://www.newegg.com/Product/Produc...k=NZXT%20gamma
get this powersupply because its always nice to have some overhead as far as power for future upgrades and addtions
http://www.newegg.com/Product/Produc...=Corsair%20750
this motherboard has been getting great reviews since it has come out recentally
http://www.newegg.com/Product/Produc...-665-_-Product
but if you want to go with a proven awesome motherboard this is the one to get
http://www.newegg.com/Product/Produc...-614-_-Product
1 - 2 of 2 Posts
