Thanks. Yes it has a side window (which I modded the case to put on it, but that needs some cleaning since the cut was uneven). I will invest in some zip ties and put everything into some sexy tidiness
I would give it like a 5/10? If you can try to tuck the cables behind the CD/HDD rack. But they do have a thread for this stuff, so for future reference post in there.
Is it that hard to resize an image? I saw the first image and thought it was a before shot, then i saw the second and noticed there was no third
Even without cutting holes, I think you could do better... Are you really using that esata bracket? Minus that and tucking the cables it'd look way better. Front audio and other small wires like the power button can also be easily ran under the board.
1 - 9 of 9 Posts
