Rattling fan
395 Views 5 Replies 3 Participants Last post by  ChIck3n
Hi, I have an Antec 3 speed 120mm fan (extra from an antec 1200 case) that I am using as a sidefan. I have it on a fan controller but when I turn it up to medium or full speed it rattles like crazy! Sometimes I can turn it off and on or kick it a little and it will go away for a bit, but it always comes back. It is not vibrations from the case, it is coming from the inside of the fan. I have tried blowing it out, no luck. Any ideas on what to do? I guess I may just have to open it up and clean it out.
1 - 6 of 6 Posts
Is it screwed in securely?
You can buy rubber fan screws to dampen vibrations
Sounds like an unbalanced fan... RMA time.
@Symek. I actually did not use screws, I have it secured with zip ties. They are very tight and the fan does not move.
@DuckieHo. Darn. I bought it from a friend who did not need it. I guess I will need to order a new fan if there is no way to fix it.
It seems to go away if I hold the fan flat, but it rattles more when it is vertical.
You can apply a piece of tape on one of the blades or hub to attempt to rebalance the fan. Of course, you would need to know how off-balanced it was....
Ok, I guess it does not hurt to try! Thanks for the input.
1 - 6 of 6 Posts
