1 - 20 of 21 Posts
I am not personally a "raver", but I do like the psychedellic aspect of it and have decided to do a rave themed mod. Pink and black will be the primary colors, any suggestions? (SilverStone TJ07)
Pink, Baby Blue, and Neon Yellow... I don't like yellow at all but the blue could work nicely with some orange...
Go to this site www.maxravestores.com and find a store near you. Call them up and ask about Rave schedules.
Read the entire first post, CattleRustler...
But I will admit, initially I thought the same
(and then I read the second post and went back to the first post)
Make the entire inside UV reactive, down to the mobo tray, EVERYTHING just UV it, all random colors, not too much yellow thought because I don't like it much either.
And put a Gigabyte board in it....those colors are enough to make anyone think they're on drugs....
You know, I personally like this idea
, are you going to be making a work log?
If your looking for the rave themed mod...It might actually be easier than you think. UV lights and cold cathodes are strikingly similar to glowsticks...not to mention that just about every possible color is available in UV Fans. Additionally - you can add the sound sensitive controllers that "dance" with music.
The hardest part will be to find the the thing you do to the case to make it a "Rave Theme" as opposed to just a very bright case. Perhaps a Window Etching or something to that nature depicting a record, a dancer, or anything else to tie it all together.
I look forward to seeing this come alive.
O sweet im gonna rave like Conan
Do not forget the mandatory strobe light and pacifier.....
Agree.
put a pacifier in the window on a small string/rope, get watercooling incase you need a drink, make sure to put the res so it can be seen. get some random strobeng led's muli color all over the inside. sound actavated neons, not bright ones, or just run off your 5v line, and get some small beans and paint then with semi gloss of flat paint to match your fav one. i miss tweety birds and pbs's, they was the stuff when i raved.
Some ideas...
The picture on the right would look pretty good on the side panel.
Originally Posted by fedex1993
This is gonna look awesome anyway, Anyone know where i can get sound modules that dance to the music?
Frozen CPU, has them, I order my CCFL's from there and they have it as an option.
QA Engineer
Originally Posted by Hewlett-Packard
Where the hell do I find a rave in FL?
Go south to Punta Gorda.
But yeah bright colors would do you good.
1 - 20 of 21 Posts
