1 - 15 of 15 Posts
I'm looking at buying Asus' p67 Sabertooth motherboard to replace my re-called UD4. Anyways, the Sabertooth recommends a top down cooler. With my case being rotated 90 degrees, and having air come from the bottom to the top, would that be counter productive?
It would probably be counter productive against it, anyway, just get a regular cooler, imo, I think they are just saying top down because they are more effective in some cases, or test benches.
I have very good results in my case on a p8p67 pro
Originally Posted by hawkeeyee
u cant have better air cooled case than raven 2 evolution..there;s no way MB will have prob in this case
I understand the case is a very good air cooling case. My issue relies more on the cooling performance for my motherboard. With Asus' claim that the Sabertooth performs best with a top down cooler, I want to try and max that performance out. But, will I be getting the best performance out of that cooler with the Raven's 90 degree rotation of the motherboard?
I'm guessing it isn't that big of an issue, but I just wanted to see other opinions. Plus, I plan on getting the Noctua NH-C14, which is a top cooler regardless of the style.
Originally Posted by EfemaN
I would guess they recommend a top-down cooler so the VRMs get some lovin'. That wouldn't change if the mobo is rotated, since the cooler is pushing air towards the mobo regardless.
I found one review that does claim slightly better performance with the top-down cooler. http://www.vortez.net/articles_pages..._review,6.html.
Wouldn't a vertical cooler see better performance in a case like the Raven, though? Since it's pushing air right through the fans + heatsink?
You could just remove all the "armor" on the motherboard. The "armor" is designed to channel all that air from a top down cooler over the rest of the motherboard.
The inside of the RV02-e is essentially a wind tunnel. I own a FT02 and it's identical to the RV02-e inside. I am willing to bet good money that the motherboard will get better airflow with the armor off and a tower cooler inside a RV02 than it would with a top down cooler and the armor on in a traditional case.
Asus isn't expecting you to have 3 X 180mm fans blowing directly over the motherboard. You would have to be crazy to think that a single 80mm or 120mm fan flowing down could provide more cooling than 3 X 180mm fans.
I would remove the armor and get a NH-D14 instead. Why sacrifice CPU temps in order to gain minimal motherboard cooling potential? Motherboard temps aren't even critical anyways.
I think that "armor" is just a gimmick. Anybody overclocking enough to heat up the motherboard will not be using a top down cooler. Anybody using a stock top down style cooler will not be getting the motherboard hot. It's a silly idea.
I have seen multiple sources claim that the armor is removable. Just take it off and utilize the massive airflow of the case itself.
Wouldn't a top down cooler create turbulence or disruption in the airflow pattern
That's what I would think. Every fan blows up in my FT02.
i think this mobo has VRM in same place as gigabyte MB?
left heatsink from CPU?
http://limages.vr-zone.net/body/11447/1-1.png
if yes than go for noctua D14 or Silver arrow...you can push middle fan down to base of cooler and then air will go directly to the VRM heatsink
in raven 2 evo my MB VRM temps droped by 6-7C
Ya, they all are set up that way by default, its sort of the entire idea of the case design
Ok first of all I apologize for bringing up this older thread.
There is a lot of good input here, but I was hoping for some further discussion.
Has anybody attempted this? Using a topdown cooler in an RV02 case? with the p67 sabertooth or not. I'm very curious.
I'm about to go with this exact setup and have been looking all over the net for further information on this. I've got an NH-D14 right now and was thinking of popping that in my other rig and buying a NH-C14 for this one.
thanks!
1 - 15 of 15 Posts
