removable DPI clutch
same sensor as dae it seems 16k
https://www.razerzone.com/gaming-mice/razer-basilisk?utm_source=Razer_Social_Media&utm_medium=smlink_US_launch&utm_campaign=basilisk_launch
looks to be a very premium scroll wheel, AND it's adjustable tension on the bottom
"With your personalized sensitivity, you will be able to more accurately perform bunny hops, weapon selects, zeroing and other scroll wheel actions."
who the hell uses scroll wheel to zero in in pubg anyways, not sure if that's even bindable but ok, i guess i will try using it when it comes, because the dae scroll wheel is garbage and i don't rely on it for weapon switching in qc at all
dpi button is removable, very upfront so not intruding the space as other old designs, BUT it still takes chunk of space off what would otherwise be a big side grip that looks like the similar design of that wireless mouse they released not few ago which name i can't even remember cus it just looks so cheap chinese knockoff brandish
also individual 1 2 buttons on the top shell with insanely thin dust lines, not sure if that will help with problems people report about designs such as steelseries 310 with huge gaps
Approximate weight 107 g / 0.24 lbs (Excluding cable)
erm..what
the skirt below the left grip tho (technically they are the same piece) can't be removed tho... the right side is your average ergo look, the side buttons on the left align perfectly with the button 1 and 2 gap, i like the design, will buy 10/10
70 bucks
erm..what
70 bucks
