So I finally managed to hit 4.0GHz on my E8400. I had to remove my 2x2GB G.Skill DDR2 800 1.8v RAM, it was clearly interfering with my OCZ Reaper 2.1v RAM. I set my vcore to 1.40, which runs at 1.328. I also added .1v to my FSB and MCH, and added .3v to my RAM to let it run at the manufacturer recommended 2.1v.
Question: my RAM is currently 5-6-6-21, and according to Newegg's specs they should be 4-4-4-15, isn't that quite a bit off? I might need some help fixing that up, I've never done RAM timing. Can I harm my RAM by trying to set it to 4-4-4-15 which is the manufacturer's suggestion? I'm running it at 2.1v which is also their suggested voltage.
http://valid.canardpc.com/show_oc.php?id=1268870
