I've had my graphic car 3 months now, i've read up and made sure I have the latest drivers, on the best settings and that the hardware is fitted perfectly as can be!!!
As most there's an 'However'...
HOWEVER... Im getting pink where white is and the temp go up at an alarming rate then crash/ freeze/ lock up... Ive reseated it, tested it in the pcie 8x slot and same results. I did install the afterburner but after 2-3 weeks it bugged the F* out of me so i removed it. The card is overclocked according to Novatech product description.
Whats strange as well it has a switch on the card:
- Performance
- s.Bios? I think
- silent
There is no difference with bios and silent regards to the temp rise and when the fans kick in at a certain speed (If you get me?)... In performance mode it wont boot up with ANY output device.
The reason for me posting this is for a last try at a fix, any ideas please leave a message and i will read them (but be serious, my patients are wearing thin)
I have contacted Novatech my supplier and they have asked to have it sent back for testing... Which means ill have no computer for 4 WEEKS (Should I send it back?)
What should I use to send it back with? nothing scarky please!!!
sam
- Performance
- s.Bios? I think
- silent
sam
