Really Need Help with bsod issue
473 Views 9 Replies 5 Participants Last post by  e_dogg
hey guys i just got a bsod and i caught of pic of and im unsure of this error. im hopping its not a memory error. i hope i just need to reformat my computer. and i just notice that superfetch has stopped working here is the log and picture
Problem Event Name:APPCRASH
Application Name:svchost.exe_SysMain
Application Version:6.0.6001.18000
Application Timestamp:47919291
Fault Module Name:sysmain.dll
Fault Module Version:6.0.6002.18005
Fault Module Timestamp:49e04208
Exception Code:c0000005
Exception Offset:000000000000c132
OS Version:6.0.6002.2.2.0.256.1
Locale ID:1033
Additional Information 1:f1a6
Additional Information 2:d2c4d5401d28587413635f914515ba99
Additional Information 3:a830
Additional Information 4:a4df21319ff8becc1ea7fe7067888bb5
thanks
1 - 10 of 10 Posts
go in safe mode and peform some checks
from the title, it would appear that an application didnt load correctly or had an error
Can you boot into safe mode???
Are you running Vista or windows 7???
Have you installed anything new, Hardware or Software???
Thanks
Comps
as far as checksdo you meana scan disk? i did that and i waiting about 30min for that.
Thanks
Comps
Yes im Using Vista 64bit. i have installed a few but uninstalled again
What have you installed?? It could be related to registered DLL's that haven't been removed in case they are shared.
Background would be helpful. Are you still running vista like it says in your sig? Have you made any major changes lately? Do you have up to date antivirus running on that windows partition? Can you boot into safe mode? As far as testing ram I would suggest grabbing memtest on a bootable cd and running that if it comes up clean my guess is that it is just windows being its wonderful self. It also couldnt hurt to reseat everything.
right now im in normal mode. fine for the time being. but the only thing i was installing was codec for wmp.. and now im getting this
Problem signature:
Application Name:SearchIndexer.exe
Application Version:7.0.6002.18005
Application Timestamp:49e03333
Fault Module Name:TQUERY.DLL
Fault Module Version:7.0.6002.18005
Fault Module Timestamp:49e0422e
Exception Offset:00000000000f6330
Locale ID:1033
Additional Information 1:e2bd
Additional Information 2:c178119d370e25c60e701070b9da874a
Additional Information 3:1b48
Additional Information 4:cf5f9c8683c605f05063c34686afdb2d
See if windows search 4.0 is installed. If it is, remove it, I had that on a server at work and it killed 2 drives.
It comes through on a windows update and that could be causing the issue ;-)
Another place to check is event viewer:
control panel > administrative tools > event viewer
Check the Application and System logs under the Windows Logs folder for any errors or warnings.
1 - 10 of 10 Posts
