1 - 12 of 12 Posts
look at this temp, best i've seen.<br><a href="http://assets.overclock.net.s3.amazonaws.com/0/0c/0ccac1c0_vbattach32820.jpeg"><img src="http://www.overclock.net/image/id/617366/width/525/height/525/flags/LL"></a>
unless your room/ambient temp is "at" or "less" than 16C = 60F your temp monitoring software isn't reading correctly. So if your PC is in a meat locker its a little hard to believe when cooling with air. Same goes for watercooling.
Air cooling can't cool below ambient temp. Try different software. My board was telling me once that mine was at 18C. It's dangerous when you are getting readings like that. I've heard of a lot of ABIT's having temp sensor problems. I know on my board the sensor reads a little high for most people. They try to fix it with every new BIOS, I think they finally got it right.
He isn't running below ambient, his system is at 16'c and so is his CPU so he is running at Ambient not below.<br />
<br />
Great temps btw
That's not ambient, unless his room is really cold.<br>
16 degrees Celsius = 60.8 degrees Fahrenheit<br>
Even then, air cooling will never get you at or below ambient.<br><br>
All three of those temps are probably wrong.
Flash the cmos. Fixed my temp reading on an Abit. They have really sketchy temp sensors, mine used to mess around if i touched the motherboard.<br />
<br />
I was getting 4* for a while though <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" />
Discussion Starter #8
nah they aint wrong. my room was pretty chilly. i just flashed my bios not too long ago so im pretty sure it is reading right. and plus i got a great cooler! owns bt any day
<tr>
<div>
Originally Posted by <strong>5t6n</strong>
</div>
<div style="font-style:italic">villainstone got around the same temps so i aint skeptical.</div>
</td>
</tr>
</table>
</div>Even the best coolers out there still run 9-13C above ambient temp at load. If you do the math your ambient temp has to be at least 7C thats 44F. Either your not telling us something or your bs'in. It is physically impossible run your cpu at the same temp as your room at load on just on air. We all know this is a fact unless you chill your cpu. Either way I doubt you sit in a frigid 44F room with you PC.<img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" /><br />
<br />
show us some speedfan
Yeah, you are risking a bunch running it like that. It must be wrong, sorry to say it, but its true. I think all your temps are at least twice what they are saying. The PWM is sending a lot of power through and it only gains a couple of degrees? What is your ambient temperature? I'd be happy to agree with you that you have a great cooler and amazing chip if you show me some proof.
Discussion Starter #12
lol i wouldnt be bs'n just to waste my own time. i didnt have a thermometer arond to check the temp but it was really cold. i run a fanless chipset cooler so i guess the cold air would make it cold to par w/ the cpu. and also speedfan doesnt work on my comp which i have no clue y. i think because speedfan doesnt have a programming for my board at the moment my temps are at 30C and its a bit warmer in here.
1 - 12 of 12 Posts
