1 - 4 of 4 Posts
ok i was just told i should check if my psu can handle 2 x 4850's in the next 2 weeks i will be adding another 4850 and a q9300 and i am concerned as to weather my psu can handle that. other thing connected are
2 x hdd's
1 x cathode
4 x 120mm fans
and a light wire
so i hope it can handle it but i can unplug the lights and 2 of the fans if needed.
Edit: also thinking of adding a h50 if i need it.
Village Idiot
You'll be fine. Overclocked 4850 CF + overclocked 940BE pulled a max of 550 watts at the wall running OCCT CPU and OCCT GPU (loads harder than ANY other program that uses GPU) at the same time. Was around 400w playing cod4.
1 - 4 of 4 Posts
