Realtemp 3.0 crashing ?
496 Views 5 Replies 4 Participants Last post by  thavmym
does anyone have Realtemp 3.0 crashing when doing the CPU test with small fft?
when i do a solo prime95 fft test it dont crash
this is with the I7
1 - 6 of 6 Posts
That sounds like its unstable...
you think so even if i do a solo prime95 small fft with out doing the realtemp cpu testing
I use Realtemp and have no issue's. Lower you overclock and Try running Prime and Realtemp again, you probably are not stable at your current settings.
turns out i Had to up my Cpu volt
this is with the I7
I have the same problem with Q9550. Realtemp freezes at the final stage of testing with prime95. Running Prime95 separately in different modes doesn't cause any problems. My PC isn't overclocked, working stable, other tests such as S&M and some RAM tests complete successfully.
I would like to ask is the problem already solved?
1 - 6 of 6 Posts
