Do you have the intel power save features disabled in the BIOS I.E C1E/Speedstep?
Yes I've disabled everything that lowers CPU performance automatically due to temperature or load.Originally Posted by TheReaperWaits;13059410
Where CPU-Z says Selection at the bottom then Processor 1, I right click and it showed me the speed for all cores. the last 2 were lower - but I just got out of fiddling around in the BIOS a little and realtemp and CPU-Z are showing everything at the correct clock, it's either happens sporadically or the few settings I changed fixed it, though to remember the exact settings Id have to reboot and find it in the BIOS then write it down which I am not up for ATM. I will try what you suggested if it happens again.Originally Posted by TheReaperWaits;13059469
How do you know what cores are at what speeds? I don't know of any feature in CPU-Z or realtemp that shows you how fast each core is currently.... Have you tried running some sort of benchmark?
If it where me I would run four instances of [email protected] and record the TPF for each core on the same WU... You should be able to tell if there is a speed difference.
Though Im just going to guess its an error in real temp. Have you tried updating it? I've never seen cores run at different speeds (not even sure it can be done).
