1 - 6 of 6 Posts
Hey all!
I just ordered the Phenom II 965 BE, along with the ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard (sorry about the over-detailed name, I'm a noob). At some point in the future, I plan to try my hand at overclocking, but at the moment I just want to get it built without it bursting into flames.
Is there a consensus on what the best mid-tier 2x2g DDR3 for this setup would be? Keep in mind that I'm not tremendously bright when in comes to this...yet.
Thanks in advance for your thoughts.
Originally Posted by sharpshoooter82
I am back again hahahahahahahah check this get the 955 will oc past the 965 and no a big deference the ram http://www.newegg.com/Product/Produc...-277-_-Product
lol man, you're like lightning. I already ordered the 965. I'm strongly considering the first set you recommended; my biggest concern is that I might by another 2x2g later down the line; will this be ok?
it will be okay but for gaming system its overkill its not bad to add 4gb more if you want to oc the memory i do not reccomd it
http://www.newegg.com/Product/Produc...-278-_-Product same thing the set is colered blue
hey bro add my rep cause i added yours
of u want to 4gb down the line make sure its the specs as the old keep all the boxs for the parts
there is rumore that soon 4gb set of ddr3 will be
$50
1 - 6 of 6 Posts
