1 - 11 of 11 Posts
I need help. I am trying to OC my computer and I think that I am having temperature problems. I can get it to boot and do all the benchmarks but when I do the torture test in prime 95. Temp2 in speedfan(not sure where this sensor is) keeps going up slowly when it gets to 40 the computer reboots. My highest cpu temp that I have seen is 49. I am trying to run at 11x228 on my 3400+ clawhammer with C0 stepping.
Administrator
49C is not really a high CPU temp. I wouldn't be sure its that.
I don't think that it is the CPU temp. I am thinking that maybe it is the northbridge temp.
If rebooting is the issue the most common cause is a failing Power Supply. Temp can be a problem also but try a spare PS see if it fixes anything.
temp 2 in speedfan is always northbridge
thats your chipset
look on your mobo for a small heatsink without a fan and put one on it this should help
if thats the problem
thats your chipset
temp 2 is northbridge? which one is cpu then?
temp 2 is not necessarily northbridge, you mobo might not even have a NB sensor. how many temps show up in speedfan? one of them is probably hard drive remember.
ill pm you w/ a screenshot cuz i dont wanna steal his thread
thats your chipset
thats not true. temp 2 on every board Ive used speedfan on has been CPU, temp one is NB.
fact is which temp is which can very in speedfan dependong on MB manufacture.l
BTW for the person who started this thread, I dont think your NB temp is the prob. at 40*c it should be fine. it is a hot chip, and on the MSI boards its known to run upwards of 45*c.
Discussion Starter #11
I know that Temp 1 is my CPU. Temp 2 I think is Northbridge. I have a temp 3 also but I do not know what it is. The HDD temperature is labeled as such. If it isn't the Northbridge that is the problem then I wonder what it could be. I have the DFI Lanparty UT NF3 250 GB mobo.
1 - 11 of 11 Posts
