Mobo - Asus P5P 800
CPU - 2.8 PresHOT
idle temps are 49
load temps have gone up to 73C!!
At first I wanted to replace the stock HS with the Blue Orb II, but wasnt sure if it would fit in the case.
Second, i was wondering about these HS, and which you would recomend as best for money/quality wise...
Thermaltake Cooling System CL-P0092 Silent 775 Heatsink w/ Heatpipe Technology, Funneled Fan (LGA775) $46.00.
SilverStone Nitrogon NT03 Heatsink For Intel Socket 478, LGA775, AMD Socket 754, 939, 940 $58.00
Thermaltake CL-P0114 Big Typhoon 4 in 1 Heatpipe Cooling For LGA 775/K7/K8 $59.00
SilverStone Nitrogon NT02 Heatsink w/Fan For P4 Socket 478, LGA775, and Athlon 64 $59.00
* considering as well * Thermaltake CL-P0257 Blue Orb II Cooler for Intel 775 AMD 939 754 - $49.99 (17dba, 77.85cfm sounds rather intruiging for the price. but setup might be a b*tch)
I plan on buying these parts from canadacomputers.com.
Thx in advance.
CPU - 2.8 PresHOT
idle temps are 49
Thx in advance.
