Recommend me a 60mm fan for my 750i FTW NB!
495 Views 7 Replies 6 Participants Last post by  c00lkatz
I was thinking this one but I am not sure if its going to have what I want.
I need a really effective noise/cfm ratio, because currently my SPP is loading @ 57c and thats unacceptable. The fan sounds louder than an airplane as well.
Let me know what you've used/heard works!
1 - 8 of 8 Posts
Have you considered the Antec spot cool as an alternative? I dont have any personal experience with it but it might be a solution.
My case is already pretty crowded :/
Any 60mm fan will be better than the stock fan. I used zipties and washers to mount mine.
Is there cleareance for a 25mm or 15mm fan?
The Panaflo FBA06A12L1BX is a nice quiet fan (3200RPM)
I'm tempted to toss one of these in to my 750i SLi board.
If I do, i'll let you know.
Looks good. And yeah clearance is 25mm. I almost could fit my shroud on the xiggy but the NB fan got in the way
I use a Delta 60MM Fan:
6000 RPm at 35 cfm But I only have it on at 3500, nb at 45 c
The particular one you have may not be that good. Just that 15 cfm may not be enough for the summer.
here's a faster and slower version:
http://ncix.com/products/index.php?s...ufacture=DELTA
I just zip-tied the fan off a stock AMD X2 HSF (4800+ Brisbane X2 to be precise) to my northbridge. At 50% constant speed (set in BIOS), it's not audible above my other fans and keeps it between 48-50*C. I think it's 70x25mm, but it fits and looks just fine. Way better than that loud, crappy stock fan. I just had it sitting around doing nothing, so I figured why not.
1 - 8 of 8 Posts
