1 - 5 of 5 Posts
Hi,
I just baught Phanteks P350X with 1070Ti. The case only contains 1 intake fan at the front. I dont have any output fans yet. Not any fan at the back of the casing.
I already ordered 3 fans and I donno how to proper setup.
Like 2 front intake and 2 at top of the case pull out? (2 in 2 out)
1 intake 3 out ??
Please give me advice.
Thanks.
9 Cans of Ravioli
You want positive air pressure so dust is less of an issue. Outside that, play around with fan layouts and see what works best. I run four intakes and no exhaust and that works best for my specific case/hardware setup.
positive air pressure means more input than out ??? Like if u have more exhaust than intake, the dust will suck to case from holes, right?
9 Cans of Ravioli
That's the idea. As long as all your intakes have dust filters, otherwise it really doesn't matter :eek:
1 - 5 of 5 Posts
