So I am BSODing every time I put high load on my CPU when doing things like rendering. I check in the BIOS and all the values are set to "AUTO" so I would like to set them back to the default before I did my clear CMOS. I think this problem is due to a low CPU voltage but I don't really know much about overclocking here so please help!
So for a 4.0GHz overclock what values should I enter?
Here are my suggested values at the moment:
Bus Speed - 200MHz
Multiplier - x20
Outcome - 4000MHz
VOLTAGE - ???
So what should I set my voltage to and what is the Highest voltage for the FX-8350? Thanks for your help!
Oh and no trolling. I wont be amused if someone tries to troll me and tells me to put the voltage too high.
When you are only just 13 and you have just practically spent your life savings on a computer, funds don't come all that easy.
Thanks for the help!
Bus Speed - 200MHz
Multiplier - x20
Outcome - 4000MHz
VOLTAGE - ???
