1 - 15 of 15 Posts
hi my system is
asus m2n-e motherboard
amd am2 x2 3800+
1gb buffalo ddr2 533mhz ram
250 gb sata western digital hdd
ati radeon x1600 pro 512mb
basically i wanna know, what settings would be good to oc the 3800+ to 2.5 ghz any settings i could try?
and yes i do understand all about ocing, but i just wann try some suggestions before i go through alot of work. thanks in advance
PS the memory timings are at 4-4-4-12
Hmm not sure, but I believe that cpu is kinda like my 3700+
Give 245fsb, 1.5v core, a try.
Discussion Starter #4
sorry to bump but im at 2200 all i did was raise fbs to 220 multiplier is 10 htt is at 4 and memory timings are still 4-4-4-12 oh and voltage is 1.4 any ideas to egt higher?
Bring htt to probably 3 just to be safe, loosen timings to like hmm...4-5-5-12 i'm really not sure what else to tell you, besides tinker with it. that is the best way to get the highest overclock.
Just go up by 5 mhz in fsb until it doesnt boot. Then mess with voltages and timings. Someone elses settings wont always work for you, ALL cpu's overclock different in some way.
Discussion Starter #9
nope none of this is helping me, the furthest i got wasd using these settings
230 fbs, muliplier at 10, voltage at 1.4, and memory timings at 4-5-5-12 and htt at 3, cant get any further than 2.3 i know i can reach higher than that whats the deal =0[
the M2N-E can't get higher than that. It''sa horrible overclocking baord. Sry.
Have you fooled around with voltages and timings?
1 - 15 of 15 Posts
