Hi all,
TL;DR: I'm looking for recommendations either for speakers (active) or speakers + amp combo. Total budget is $400 CAD ($300 USD). I'm located in Canada.
Context:
I've salvaged an old record player. Fisher MT-273
I also replaced the stylus (original needle was missing) with an Ortofon OM 5E. Basic stylus; Nothing fancy.
Now, I plugged record player directly (RCA -> 3.5mm) into my Bose Companion 3 Series II Speakers (multimedia unit for desktop). However, at full volume, the record player was audible... but not loud enough to listen from a distance. I assume the built in amp in the bose speakers isn't powerful enough to drive it.
In any case, its clearly not the right application for it.
Request:
I'd prefer to have better speakers dedicated for the unit.
Preferably something active so I can avoid purchasing more equipment.
The project (record player refurb) is under the management of my partner in crime
She wants it clean and elegant. I want quality sound and efficiency on the budget...
In the event we move away from playing vinyls, i'll likely relocate the speakers to either my TV or PC in the future.
I need your help to find the best value (cost/performance/size/appearance).
Questions:
What is the best approach?
Let me know if you can help!
Thanks
Context:
Request:
Questions:
- Active speakers?
- Passive + amp?
- Do I need a preamp in any of these situations?
Thanks
