Exactly. Thanks for that photo. I need a male RCA to 3.5mm aux for output.
I only purchased / have a female RCA to 3.5mm aux as I needed to connect the TT to the existing speakers (amp).
And yes, my bose speakers sound decent and look nice.
I assumed I needed to find something more powerful before creating this thread. I didn’t understand my requirement for a preamp. Thank you T.sharp for confirming
You could also get a cheap RCA interconnect cable (male - male) and use it with the 3.5mm adapter you have. Might save you a couple bucks and you would be able to connect the preamp to anything with RCA inputs in the future.
Glad you got it sorted out 🤙
EDIT: you should snag a carbon fiber record brush if you don't have one already.
I'm not exactly sure what you mean but they are self powered, they do not require any extra stuff to work unless you need a cable adapter, but definitely no additional amp.
They are self powered and compatible with conventional devices like computers. However, through my brief research, record players require a “phono preamp”.
Maybe the edifiers have the preamp, maybe they don’t. Im not too sure.
The ultimate guide to turntable and record player setup. Guide includes recommendations on required gear/equipment and what to look for when purchasing a turntable.
blog.fluance.com
Anyway, my goal was to build out a cheap record player station with my fiancée. Reusing my speakers, even if they are very “multi-mediay” and not studio monitors, should do the trick. My total cost will go down significantly if all I need is the preamp / cables as suggested by T.sharp.
I use my 6XX headphones for PC on a typical day. So I don’t mind sacrificing my speakers for this project.
Maybe i’ll now need a dac/amp for my headphones. Maybe ill buy new speakers for my desktop. Not sure. Thats for another day.
On a side topic, for those interested… here is the result of 180 grit sandpaper and one coat of teak oil.
blog.fluance.com
@Slaughtahouse - I just wanted to pop in and add that if you check out your local Goodwill/thrift stores you will every so often find quality wood cabinet speakers that pair well with record players. Anything with the Fisher brand name is worth a deeper look and my buddy scored a very nice pair of Fisher wood grain tower speakers not long ago for $35.
Because they are so big and bulky I'd bet you'd be hard pressed just to ship speakers for that much so buying in store has huge advantages here.
The ones we scored look like the photo below. Must have been owned by a careful owner as they don't show their age at all. Sadly one of the side effects after the covid stuff is that the market for vintage items is at an extreme low and deals are ever-present.
The truth is that I was passed down everything need to get it going. Everything I received was original and from the 1980's. Including tall speakers (looked nearly identical^^), old amp/receiver, and the record player.
However, after setting everything up... I noticed why the record player sat unused.
The speakers were beyond repair. After removing the foam, I discovered paper towel was shoved in-between diaphragm / black suspension gasket looking thing. That was there to muffle the vibrations lol. Record player was missing the needle from the Ortofon 20 stylus. Amp/receiver probably worked but since it was a) giant and b) everything else was unusable without intervention, I gave it back and parked the project.
I think once we went into lockdown AGAIN and it basically lasting the entire spring in Ontario... my fiancée wanted to reboot the project.
So we ordered the new stylus (Ortofon 5E) a couple weeks ago, and she found the used media unit. I thought (unknowingly) I could just plug it into my existing speakers. Because they have their own "amp".
Next step was to validate a preamp. Which I should of known before labeling this thread "speaker recommendations" but I wasn't sure.
Fast forward to today. I have everything I need but the cabling. It should arrive today and yes, I ordered the preamp as recommended by T.Sharp. I hope it's compatible. I didn't know there is a difference between MM and MC cartridges...
TL;DR: I'm looking for recommendations either for speakers (active) or speakers + amp combo. Total budget is $400 CAD ($300 USD). I'm located in Canada.
Context:
I've salvaged an old record player. Fisher MT-273
I also replaced the stylus (original needle was missing) with an Ortofon OM 5E. Basic stylus; Nothing fancy.
Now, I plugged record player directly (RCA -> 3.5mm) into my Bose Companion 3 Series II Speakers (multimedia unit for desktop). However, at full volume, the record player was audible... but not loud enough to listen from a distance. I assume the built in amp in the bose speakers isn't powerful enough to drive it.
In any case, its clearly not the right application for it.
Request:
I'd prefer to have better speakers dedicated for the unit.
Preferably something active so I can avoid purchasing more equipment.
The project (record player refurb) is under the management of my partner in crime
She wants it clean and elegant. I want quality sound and efficiency on the budget...
In the event we move away from playing vinyls, i'll likely relocate the speakers to either my TV or PC in the future.
I need your help to find the best value (cost/performance/size/appearance).
Questions:
What is the best approach?
Active speakers?
Passive + amp?
Do I need a preamp in any of these situations?
We're not audiophiles. It's just a fun mini project.
This has been said for the last 25+ years - "No highs, no lows, must be Bose" Your using dated equipment thats not even hooked up correctly. All you need is a Pre-Amped Dj monitor speaker (one is enough) - mixer. Budget and sound sometimes you really get what you pay for. Find some audio place near you and ask them for help. You want speakers with good frequency response
I like your Bose response lol. Yes, I know they’re not quality speakers. It’s simply what I have but I expect some to rub the salt in the wounds
I assumed when making this thread I NEEDED speakers. I learned that I don’t. See pre-amp discussion.
Now, I need to validate that we WANT to go further with the investments (speakers).
So, we’ll be playing some vinyls we own over the next few weeks / month. If we are really enjoying it AND we want to get more out of our setup, I’ll spark the discussion again.
This isn’t really meant to be a high quality setup. I was more concerned with the spend to be straight. I didn’t want to dump $500+ into a record system we don’t utilize.
You should try and find some flac audio files that are the same tracks as something you have on record and I'd possible play it both ways on the same speakers and see if you can tell the difference.
Hmm.. don't confuse them. They are still working on the mini system. Why no just invest in some used HiFi gear off the local CL/FB and get you a system up and running. I mean you can still run your computer through it as well. It is all about the ear you have and what sound you wish to get. I got a set of 3 way Sony speakers that are dime store garbage that sounded like a no life, I went back to the dinky 2 way Sony bookshelf speakers. The two ways produced a better bass hand highs then the other bigger ones.
I think once you get where you are you may want to expand out if your lifestyle desires it.
I think the 3 ways I paid 15usd dollars for and the 2 ways I paid 25usd for both thrift stare finds. I can say the 2 ways pair up with my former Denon and current Marantz. They don't get used much as they really need dusting and cleaning.
It is all cool but with albums never played it is best to setup a tape deck or reel to reel and do a first play recording then use the tape after. it preserves the albums.
I have a Radio Shack hysteresis wound turntable w/ diamond needle. You most likely won't find that one anymore, but the operative word is "hysteresis wound", which adjust for line voltages fluctuations and thus reduces wow. What you need is a stereo tuner and no need to break the bank as I use a fairly inexpensive Yamaha with my big screen surround sound TV setup in my basement bar area. I believe Best Buy is the place to shop - maybe in the $250 area. If you're not into 5 speaker surround sound then left-middle-right will do. I would check-out the Edifier line. I have a set of bluetooth Edifier's on my gamer and they are fine. Go to a shop that has some speakers setup and see what suits you.
So just a follow up for anyone who ends up searching for speakers and coming across this thread.
We ended up purchasing a pair of Audioengine A5+s.
I added an Amazon Echo dot to it for wifi music streaming for an additional ~$25 CAD.
As it turns out, we really like the vinyl player setup and use it very frequently.
I imagine the next step will be to replace the cheap piece of furniture we got as its clearly too small for our current equipment.
After that, replace the TT / needle in the future but it will be a slow and steady project as time / funds allow for it.
Thanks everyone in this thread for help, support, and feedback.
21 - 40 of 40 Posts
