I think this is similar to the other thread (http://www.overclock.net/t/1308966/recurring-bsod-caused-by-ntoskrnl-exe/10), but the specific crash errors are different.
Hey all. I have been getting various blue screens on and off for the last few weeks since I built my new computer. They haven't been constistently triggered by anything, but happen every few hours now.
Happens when gaming, streaming, and just browsing the internet sometimes. I have tested known working memory from my old build but still got crashes. Everything on stock speeds, overclocking seems to be the same.
Dump Files: (From the program whocrashed)
Whea_uncorrectable_error has been the most common one, but the various kernel errors were happening a lot before.
What I have done:
>Reinstall windows with the disc > reinstall and keep all files
Am planning on doing the "refresh option", not sure if will actually help.
>Swap out ram for other working ram
>Disable integrated audio drivers, were causing problems before.
>Try various nvidia drivers, stopped the blue screens from nvidia (was on beta before, switched to stable)
Will paste more dump files as i get them
Operating System
Windows 8 64-bit
Intel Core i7 4770K @ 3.50GHz 48 °C
Haswell 22nm Technology
16.0GB Dual-Channel DDR3 @ 798MHz (11-11-11-28)
Gigabyte Technology Co., Ltd. Z87X-UD4H-CF (SOCKET 0) 28 °C
Graphics
Acer X233H ([email protected])
Intel HD Graphics 4600 (Gigabyte)
2048MB NVIDIA GeForce GTX 760 (MSI) 34 °C
Hard Drives
119GB Samsung SSD 840 PRO Series (SSD) 36 °C
932GB Western Digital WDC WD10EZEX-00KUWA0 (SATA) 36 °C
Optical Drives
No optical disk drives detected
Audio
ASUS Xonar DG Audio Device
Windows 8 64-bit
Graphics
Hard Drives
Optical Drives
Audio
What I have done:
On Sun 8/25/2013 12:59:24 AM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\082413-4859-01.dmp
This was probably caused by the following module: hal.dll (hal+0x2D93D)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008E12028, 0xBA000000, 0x52000402)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\WINDOWS\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sun 8/25/2013 12:49:51 AM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\082413-15031-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800F13C028, 0xBA000000, 0x52000402)
On Sat 8/24/2013 10:29:18 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\082413-10375-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7B040)
Bugcheck code: 0xC000021A (0xFFFFF8A000447930, 0x0, 0xFFFFFFFFC0000001, 0x2B93180580)
Error: STATUS_SYSTEM_PROCESS_TERMINATED
file path: C:\WINDOWS\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: This means that an error has occurred in a crucial user-mode subsystem.
There is a possibility this problem was caused by a virus or other malware.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sat 8/24/2013 10:24:52 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\082413-12296-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFFA800CEAA000)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
On Sat 8/24/2013 9:03:07 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\082413-5406-01.dmp
This was probably caused by the following module: Unknown (0xFFFFF80175CFA040)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800F0BA028, 0xBA000000, 0x52000402)
A third party driver was identified as the probable root cause of this system error.
Google query: WHEA_UNCORRECTABLE_ERROR
On Sat 8/24/2013 8:42:59 PM GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\082413-5093-01.dmp
Bugcheck code: 0x139 (0x3, 0xFFFFF8015C3233C0, 0xFFFFF8015C323318, 0x0)
Error: KERNEL_SECURITY_CHECK_FAILURE
Bug check description: The kernel has detected the corruption of a critical data structure.
