1 - 3 of 3 Posts
You can remove the Recycle Bin from your desktop, without loosing the ability to delete files. You can still right-click on a file and select Delete, as well as using the Del key on your keyboard. Furthermore, there will still be a Recycle Bin directory on every drive. To add the Delete option to the Recycle Bin's context menu, follow these instructions:
1 - 3 of 3 Posts
