Project 1. EPIC window chiller
Decided to change the whole layout of the project. I am going to make a bench that holds 2 maybe three rigs worth of parts that will be cooled with 2 rads outside. I will have a seperate loop connected to another rad outside that is going to be routed to two rads inside that will be blowing cold air at the ram/gpus on each rig. The idea is to get all of this done without effecting the inside temp too much. Last winter had a similar set up only room temp was way too low for comfort might as well have been benching in the garage. Ive been doing some testing and I think I have everything covered exept for a third psu and I am hoping I have enough pumping power but I should. Wont have any more money to add to the project so it will be fun. Oh yea will also try and make my 775 rig so I can easily swap a pot in. Should be doable because its the same diameter as the block. Ill keep you updated I hope to finish in two weeks.
hehe I said pumping power
